TwinTurbo.NET: Nissan 300ZX forum - Try a bottle of water wetter to see if that helps it. (n/m)
Josef(Houston)
on May 13, 2008 at 5:03 PM
Opinions on Water Pump OD pulley....
posted by MrHypnotik
on May 13, 2008 at 02:25 PM
MrHypnotik
14:25:01 05/13/08
maybe your fan clutch has gone bad? (n/m)
Ahmed
14:37:34 05/13/08
1) There might be a pocket of air in the system that needs
Dave N
14:55:00 05/13/08
You need to fix what ever current issue you have 1st. (n/m)
Woody75 (Denver)
14:57:14 05/13/08
Re: You need to fix what ever current issue you have 1st.
MrHypnotik
16:50:08 05/13/08
electric fans would be a downgrade imho (n/m)
aliaZ
17:23:05 05/13/08
Definitely follow everyone's advice on the fan clutch
HillZTT
18:25:34 05/13/08
Woody's right, you need to fix your underlying issue.
Guapo
15:25:01 05/13/08
Try a bottle of water wetter to see if that helps it. (n/m) -
Josef(Houston)
17:03:58 05/13/08
sounds like air bubbles, bleed the cooling system and see (n/m)
sandmanz32
18:02:59 05/13/08
OD water pump pulley is primarily for UD crank pulley
twinturbineZ
20:12:29 05/15/08
